oldboat1
- Apr 3, 2002
- 9,612
Re: 1956 Evinrude Q's - pics
OK! but now you need another motor to use with that extra flywheel nut.
I would take it as a good sign that the compression is even between cylinders. Where are you with the lower unit stuff? in process of replacing impeller, or beyond that already? Curious about the electric starting system too. I've never converted a 6 volt system, but maybe that is nothing more than changing out the starter?? (High Trim -- you there?) Likewise, I'm not sure how to tell whether it's still a 6 volt system, other than maybe damaging a 6 volt starter, I mean. I've heard of using 6 volt batteries (old tractors, maybe), and think they would be available.
will keep checking in to see how it's going.
