I got the water pump out of this thing finally. The drive shaft was somewhat worn below the pump housing.
The bottom part of the housing has a slight crack in it and is kind of dished out. I'm concerned that it will not seal over the intake tube that it sits on.
Is this an issue?
I was hoping to just replace the impeller.
Should I go ahead and buy a the whole #763758 water pump kit? I've read in some of the other posts that it is a little different.
Is this an issue?
