1956 10 hp johnson lower unit removal?
section8
Hey guys. can anyone tell me how to remove the lower unit to get at the water pump. i removed the 5 bolts and it dropped about an inch but then its stuck. im sure someone asks this frequently so once i post this ill look at the links it creates at the bottom of the post. Thanx alot! Erik
tashasdaddy
Re: 1956 10 hp johnson lower unit removal?
remove plate on the side of the leg, remove bottom bolt on shift connector
section8
hey thank you. ooops! i went outside and saw that cover and i undid the upper bolt. is this bad or no biggie? it worked. Thank you
section8
oh. and i have used the iboats store a few times now and i agree. good prices and speedy shipping.
I don't feel that it is an issue that you took the upper bolt out. A trick that I have used is to hold the lower unit portion of the shift shaft and push down on the shift lever lightly to seat the shaft into the coupler. A little grease helps with this. I like to also coat the top of the drive shaft with some grease as well. Hope this helps.
