1955 Johnson 10hp yay or nay?
Chevyls6
After selling my junk evinrude 9.5 for parts today im on the hunt for a different kicker. Anyone know anything about a 1955 johnson 10hp? Theres one near me for a reasonable price that seems to be in good shape and is supposed to run.
I know about the 24:1 oil mix which will require 2 gas tanks which kinda sucks.
You will meet a lot of nice people with a smooth running old outboard motor.--------The 55 model has the same gearcase ( different gears ) as the 18 HP models.-----One draw back is the bushings on the wrist pins if still original.------Best way around that flaw is to install pistons and rods from say a 1962 model 10 HP
Chevyls6
What was wrong with the wrist pin bushings? Is it because they werent needle bearings?
????------They were bushings !-----The last few years of the 10 HP model used a needle bearing there.----And it is the very same needle bearing as used on a V-4 125 HP motor in 1972.-----So on a 10 HP it was adequate for the job.
F_R
The wrist pins would be my first question also. But don't jump to conclusions---they are easy to check for looseness. Remove both spark plugs and use a screwdriver to follow the pistons down as you slowly rotate the flywheel. Just follow the piston, don't push. When the piston is half way down, stop turning the flywheel. Now, give a push on the screwdriver. A clunk and movement indicates wear. A microscopic movement is normal and ok. 1/16" of clunk is on its way to the graveyard or rebuilding. Or it will run till a wrist pin falls out and goes boom.
BTW, the rod bushings were not the whole problem. The real problem was the wrist pins were too small in diameter and would beat the hole in the pistons to death. The newer parts include needle bearings, pistons, con rods and larger wrist pins. You have to replace all or nothing.
lindy46
The later models had the needle bearings but the gearcase was changed to the same gearcase used on the 5.5 and 7.5 HP motors. I believe the change was made about 1958. The smaller gearcase had a driveshaft bushing in the case by the pinion gear which was prone to early failure in the more powerful engine especially if water got in the gearcase. Too bad they couldn't have combined the best features of both motors.
Chevyls6
Good info everyone
I ended up passing on the deal because there was nothing but water in the lower unit when i got there...
still on the hunt for good quality kickers up to 10hp
Does anyone know when the fuel mix switched to 50:1? Having 2 different tanks with 2 different ratios for the same boat is something id love to avoid if i can lol.
Doh
I had a 1958 10hp Evinrude, (burnt into a puddle when my Shed burnt) It ran Great. Started on 1 Compression Stroke every time.
Problems were. 2 line fuel tanks. Any Air Leaks cause No Runs. It had an Extenda Handle, Metal Grip, that would send Spark Plug arc through your hand @ 3/4 Throttle. Grounding the Motor to the Boat curded that, and no ill running because of it.
The 2 line tank is actually far superior to some of the plastic junk available today.
Chevyls6
Those old metal tanks do feel more sturdy than the plastic ones.
Plastic tank means no rust though.
Fixing up an ----ACTION MARINE 17------ It will have 3 steel 6 gallon tanks in the back.-----No plastic junk for me.
