Anthonyfasttwin
- Sep 3, 2011
- 30
I just purchased a 1955 fastwin aquasonic #15014 it had been sitting for some time prob 10 years. I changed the spark plugs replaced the fuel lines and she started right up. I took it out on the lake today for the second time running 24 to 1 gas oil mix, good bit of water spitting out the exhaust. Ran pretty good for a little while then it started jerking and running really bad low speed and wide open throttle barley going. The rev would go up and down up and down for a while then die. Also it made different noise tones kind of sounds like a knock then more quiet then back to a knock sound. I drained the lower end and it was milky. I would really like to make this old motor run like a champ I just don?t know where to start, what parts I should get, and what work I need to do to it? I?m at a loss with part numbers, service manuals and know how. This will be my first out board project. Any help would be greatly appreciated. Also I would like to know if these motors are any good if not then I will just let it go and what is the difference between a regular fastwin and an aquasonic fastwin?
