1955 evinrude on 52 Lyman
cbouchard
With all the advice I have received over the last couple of months the motor is running great. I have one small problem/question. I put a ignition switch on it that is supposed to shut the motor down by connecting each set of points together which I understands grounds them out and kills the spark. Only problem is that the motor keeps on ruinning and I have to choke the motor to shut it down which is no problem except that I want to put a kill switch on it that my grandkids have to connect to their pfd . What I did was put in a new wire from the upper cylinder points and then picked up the wire coming from the bottom cylinder to the vacuum cutout switch. Then connected them to each of the wires marked m on the ignition switch. The ignition switch works correctly in that when the switch goes to off the two wires form a loop and because each is connected to the separate wires coming from the points there is a loop that should ground the points out..correct??? Can I just attach a wire going to the engine ground and when the loop is created it will definitely shut the engine down? Is there a possibility that I could short out a coil or something? Thanks, cliff
F_R
Honorary Supreme Mariner
A lanyard kill switch should be all set to go with your wiring as is. It simply connects to the two "M" terminals along with the wires leading to the points. Either switch will then kill the ignition and stop the engine.
cbouchard
I need to check the wiring again because the ignition switch DOES NOT shut the engine down. Thanks for your confirmation of what I thought to be the proper wiring.
cbouchard
Perhaps I have connected the m post wires to the wrong spot on the points...I have connected them to the same lug on the points on which the condensor is attached..is this correct??
F_R
That is correct. I think I read your post correctly (?). 1955 did not have an ignition kill function, but your modification should have converted it. Anyway, bottom line is one "M" terminal goes to one set of points, other "M" terminal goes to other set of points. Vacuum cut-out switch is also connected to points for bottom cylinder.
F_R
Like this except '55 vacuum switch case is grounded instead of thru the mercury switch.
cbouchard
That is exactly what I thought I wired need to go back and double check..thanks cloff
