1955 Evinrude Fastwin 15 hp 15014 needs tune help
steinbro
I was hoping someone could help me understand and if I can correct that I have a 1955 Evinrude Fastwin 15 hp that runs ok. It runs ok with cover off but does do a like jolt shake ever so often like it gets caught and kicks a little but still runs?
F_R
Honorary Supreme Mariner
Feels like you hit a rock? Or here in the South, like you hit a gator? Very common. It is coming out of gear, rotating half a revolution, and slamming back in gear. Watch or put your hand on the shifter lever to verify.
If that is what it is, you need to check clutch dog and gear in lower unit, and shift linkage. Don't delay, every time it jumps, more damage is done.
tomhath
Master Chief Petty Officer
The other possibility is that you're seeing a "lean sneeze". Try opening the mixture knobs a little to make it a little richer.
steinbro
This a picture of the clutch dog and it seems like its wearing on the 1 part see shiny part. what to correct this?
F_R
That dog was worn out long ago. Check where it matches the forward gear, it probably is worn too. Cure is replace the worn parts.
Yeah, somebody will tell you to reverse the dog and run it. That may work awhile. Depends on the condition of the rest of the parts.
steinbro
Does anyone know models years and hp that is match same parts I know there is usually a range of years and models but can not find?
F_R
375711 clutch dog fits 14 & 15hp 1951-1956; 18hp 1957.
steinbro
F_R with replacing this clutch dog do ya think this would be the culprit to kick I have been getting? or is there more to consider to look at as well? The gears look ok to my eye but will add a picture soon for that to get a take on it.
54bobby
try running it while holding the shift lever forward nice and tight. if the symptoms stop, most likely it's the clutch dog.
lindy46
Look at the mating surface on the forward gear and you will probably see a similar wear pattern. The gear teeth may be fine, but it is the inner part where the clutch dog ear meshes which wears. I'd replace both gear and clutch dog. That should solve your problem.
steinbro
Ok will be looking at soon. Also i did notice when running there was a milky color in water exiting when taken out of tub to do work on lower unit. Any ideas?
F_R
That's the oil that you put in the gas. It has emulsified with water. Normal.
steinbro
Ok so took lower end apart and reset all to be proper. And when i have it together it seem as if the shift rod does not allow the clutch dog to engage on gear farthest from the prop. Any ideas?
lindy46
Is the pivot pin properly installed through the hole in the shift yoke?
steinbro
Yes pin is thru shift yoke and in slot to pivot. the clutch dog just does not travel the whole way back due to the shift rod travel room. I will include picture later.
F_R
How much slop is there in the shift rod? When you move the shifter lever, does the rod respond without delay? That jumping and banging may have damaged it where it connects below the powerhead
F_R
Another thought: The forked lever in the gearcase may be bent. Happens when people force it.
