1955 Evinrude Big Twin 25hp Restoration
carl2782
Hi, got a line on one of these motors that will be a great fit for my little boat. I'm unsure of the condition of it right now but assuming it will need a rebuild - first question of many which I'll be posting, would a later model (1969) 33hp powerhead fit? My understanding is it is only the head and thermostat (or lack of in the earlier model) are different. Any other considerations in thinking about that swap? Will the carb from the old 25 work?
Thanks in advance,
Carl
F_R
Honorary Supreme Mariner
It will bolt on, but you will find differences. First one will be mounting the hood. I'm not sure if the 33 has the hood mounts on the cylinder head or not. But I think not. Also, the 33 does not have a thermostat, but the bore is larger anyway so changing the head to get hood mounts probably isn't going to be a good idea either.
Yeah, you probably will have to use the 25 carb and silencer & needles & choke, etc. Hood problem again.
Why do you want to put a 33 powerhead on it anyway? For the 8hp?
carl2782
Hi, thanks for the quick reply. It's not about the 8hp, although that would be a bonus. Only reason for asking is I saw a decent looking 33 powerhead for sale and thought it might save some work on the 25 if it is seized. By hood mounts you just mean the cowling, right?
carl2782
Bumping this back up for some advice as I've been moving forwards with this one. Got the motor home, sprayed some penetrating oil in the cylinders and she turns! So figured I would do a compression test next to see what I have on my hands. It reads just over 60psi on the top cylinder and just under on the lower. Should I be concerned about that on this vintage motor? I have read some contradictory things online. Obviously this was tested cold, with the pull cord and I'm not a pro at this.
lindy46
That's low for a 25hp. Let her soak some more and try again. At least both cylinders are about the same. Sometimes once you get them running, numbers improve.
HighTrim
Pull the bypass covers off, and see if the rings are stuck. If stuck, we can deal with that. They should bounce, when you push on them with a small screwdriver.
carl2782
Took the bypass covers off for a look. Everything seems good there. All 6 rings have a bit of a bounce when pressed. Anything else I should be looking at?
carl2782
Does anyone know what part # is the correct powerhead gasket for this motor? Looking at 304545, but there are a couple that look very similar.
F_R
Original number was 303974 changed to 304545.
So, you have the powerhead off? You need to know that there was a major mid-year change in that model. The change resulted in disaster. Look at the seal at the bottom end of the crankshaft. If it is a carbon seal held on with a spring, you are good. If it is an ordinary lip-type seal, look out.
F_R
Following up, your compression is too low. If you have the lip seal, your low compression could be part of the disaster I just spoke of.
carl2782
Thanks F_R. Needed to take the powerhead off to replace the shifter. I'll take a look at the seal today.
carl2782
No Title
Here's a look at the seal... doesn't look good. Any advice on next steps?
F_R
Somebody created a conglomeration there. From what I can see, it had the lip seal but somebody put the carbon seal spring on top of it. Well anyway considering the low compression, it probably should be torn down and inspected. Your choice, I suppose. But what happens is water gets past that seal (or lack thereof) and into the crankcase where it wreaks havoc with all the bearings, etc. Without looking, it is hard to guess how much damage has been done.
If you do decide to rebuild it, replace the lower main bearing with the one made for carbon seal, as well as install a carbon seal.
carl2782
Thanks again. I guess I'll start tearing it down. I took this on as a tinkering project anyway. Stay tuned for lots of pictures and questions.
carl2782
No Title
Got her almost all torn down last night... just one head bolt rounded off unfortunately. Gotta find a way to pull that one today to get a look in there. Here's some pictures. The crankshaft bearings feel tight to me, even though there is some surface rust on the crankshaft as you can see here. Anyone see any red flags in here I should be concerned about, or have any tips on how better to evaluate the condition of it?
carl2782
Oh, and any tips on where best to buy a gasket kit, seals, bearings if needed? Had a look on iboats but it doesn't look like internal parts for this motor are available. Any suggestions on getting that rounded off head bolt out would also be helpful. I have it soaking in some penetrating oil right now, currently thinking I'll just buy some decent vice grips and give it a go with those.
carl2782
MOrning Experts. Trying to do my shopping list for this, and struggling a bit to find that parts for that lower seal. I found the seal itself, but need the spring and retainers. Does anyone have those part #s? They don't show in my manual unfortunately.
carl2782
No Title
Got that head off today, so here are some more pics of what I'm dealing with. The lower cylinder (second pic) has some rust in there. Is this fatal? Any suggestions?
F_R
No Title
You need to tear it on down to inspect the bearing surfaces. You do not want to find etching where the rollers have laid. If you do rebuild it change the lower main to the one that uses a carbon seal.
Here is the parts list. Be careful, it shows both kinds of lower bearing & seal.
