1955 evinrude 15014 fuel pump
oletimer60
I'm wanting to converting my 15hp Evinrude 15014 Mtr over from old 2 line gastank to 1 line tank system and add a fuelpump. I heard it's possible?? Can someone point me in the right direction with pointers and tips?
RCO
It is pretty straight forward. You can either find a transfer port cover with the fuel pump mount and pulse port for the later OMC square fuel pump, or drill and tap your existing transfer port cover for a fitting and run a Mikuni or Kohler type pump. Then you will need to cap off the existing pressure fitting on the reed plate, and install a single line fuel fitting. I just did a 58 Fleetwin, and parts were under $25.
F_R
Honorary Supreme Mariner
No Title
A Briggs & Stratton pump mounted on a similar motor. One hose goes between fuel connector and pump, other hose goes from pump to carburetor. Short hose is pulse hose from bypass cover. Pump mounting bracket is home-made.
EDIT: Yes, somebody with a sharp eye will notice that an OMC factory pump could have been directly bolted to the bypass cover because it has the mounting holes.
oletimer60
Looks to be simple.Thanks guys, Question to Supreme Mariner tho, pulse hose,..... In the pic you posted, do I connect to the existing pulse port on the opposite side of the motor? or do i plug that one off and use the port shown?
F_R
I don't quite understand the question. Are you speaking of the port/hose that now pressurizes the tank? If you are, yes simply plug that hose. That really isn't a "pulse" hose suitable for operating a fuel pump. The setup in the picture obtains a true "pulse"--that is an alternating pressure/vacuum pulse with each rotation of the engine.
witt20
please share pictures as you do this. I am doing the same modification. I already have the Mikuni type pump, and a Mercury tank to feed it, so I wont be using the original 2 hose connector at all.
