1955 7.5 evinrude m#7518 1955
UPRON
:mad:Lower unit rebuild what parts do you reccomend I took apart o ring looked ok? shaft seal looked ok? gasket looked ok Barrel of water I test ran in was full of oil . Lower unit
lube all milky.
jbjennings
Re: 1955 7.5 evinrude m#7518 1955
I personally would recommend a new seal kit installation, since the whole kit is only about 30 bucks. Go ahead and get it over with, it's not that bad. New impeller for the water pump while you're at it. You can't tell if a seal is bad by looking at it, from my experience.....
You asked,
JBJ :)
UPRON
What all comes with seal kit and where do I get one. Thanks
