1955 3 hp seaking
catfish125
I just got a 1955 3hp Seaking. It starts and runs really good but the motor is getting really hot. Anybody have any idea what would cause this? Maybe water pump????
JB
Re: 1955 3 hp seaking
Look at the leg when it is running. Is there a spray from the back of it?
You probably need a new impeller in the water pump, but that is not the only suspect. Fortunately JohnnyRude parts from that period work just fine.
F_R
Honorary Supreme Mariner
Please don't burn that motor up. Replacement pistons are next to impossible to find. I'm looking for one now.
That motor has a "wobbler" pump just fwd of the propeller. The rubber impeller (properly called a "rotor") swells up from grease leaking out of the gearcase. Brian Wilcox makes them-- http://www.chrystine.com/impellers/order.html
catfish125
thanks no i shut her down right after I saw it getting hot and noticed no water spraying out the exhaust. Thanks for the information.
F_R
The rotor must be the same thickness as the depth of the housing, and fit closely to the eccentric on the inside, and just touch the housing at some point on the outside. There should be a space on the opposite side from where it touches. As the shaft turns, the space appears at the intake side, and progresses around to the outlet side, where it disappears. Then it appears again at the intake side. Each time it goes around, it takes a gulp of water with it and pushes it up the outlet/water tube to the powerhead.
The tab at the top has nothing to do with it other than separating the intake and outlet sides, and preventing the rotor from spinning.
Early models had holes in the propeller, which forced-fed water to the pump. Later models had a propeller hub slightly larger than the gearcase, which caused a scoop effect from forward motion to feed water to the pump.
catfish125
Thanks again for the information I am going to take her apart this week and hopefully get that part ordered.
