Can anyone tell me what the bottom end of the reverse lock rod spring connects to?
V vpedpa Cadet Thread starter Joined Mar 14, 2010 Messages 8 Sep 11, 2010 #1 Can anyone tell me what the bottom end of the reverse lock rod spring connects to?
1946Zephyr Vice Admiral Joined Oct 21, 2008 Messages 5,556 Sep 11, 2010 #2 Re: 1954 Evinrude 7.5 hp reverse lock rod spring Here in this link is a good break down of your lower unit. This is for a '55 model, but it's the same as yours. http://www.marineengine.com/parts/v...evinrude-johnson/FORM_2100/FORM_210000001.htm Your reverse lock down spring should be locking down on the tilting lever assembly (76 on this diagram) http://www.marineengine.com/parts/v...evinrude-johnson/FORM_2100/FORM_210000001.htm
F F_R Honorary Supreme Mariner Joined Jul 7, 2006 Messages 28,226 Sep 11, 2010 #3 Re: 1954 Evinrude 7.5 hp reverse lock rod spring Is this what you are asking? Attachments 100_0252.JPG 87.9 KB · Views: 1
V vpedpa Cadet Thread starter Joined Mar 14, 2010 Messages 8 Sep 14, 2010 #4 Re: 1954 Evinrude 7.5 hp reverse lock rod spring FR That is it. My lower unit doesnt have the reverse lock lever for the spring to connect to. Is it absolutely necessary? What does it do?
F F_R Honorary Supreme Mariner Joined Jul 7, 2006 Messages 28,226 Sep 14, 2010 #5 Re: 1954 Evinrude 7.5 hp reverse lock rod spring Keeps the lower unit from tilting up out of the water when you put it in reverse.
