1953 rd-15 25hp seahorse!
IndyFish
Added a 1953 or 54? rd-15 Johnson seahorse 25hp. I can't find a single parts diagram online for one, or even anyone who sells parts. Robbed a donor motor for ignition coils and I had condensers sitting on my shelf from another pre 60's Johnson build and fudged my way through the carb being careful of old gaskets (only had to make one out of gasket paper), but I can not find an impeller! I ran her for about 5 seconds in a barrel but shut it down because of no water flow.
anyone got advice on where the heck to get impellers, or someone know what else will work?
It is the old, old, oooooooold style with no water tube going to the pump housing. The water diverts around the side and to a tube cast into the housing. Which means that the other seahorse impellers any later than this one will not work. (different size shaft)
I think this one will be a runner. ORIGINAL OWNER said he only remembers having it out a handful of times. Under 10 hours on the motor for sure. everything under cowl is brand new shiny. None of the bolts even have mar marks on them from being taken off, etc. Cowl and outside is pretty dull, but due to sitting in the rafters of his garage for 60 some years
can post pics if anyone is interested in my little build
IndyFish
ha, actually our website has em! I haven't had much luck in the past looking up parts through them. sierra 18-3006
thanks iboats
kat-a-tonik
You may also find the parts at Napa, so far they have gotten me anything I need for my 58,63 and 66 Johnsons
F_R
Honorary Supreme Mariner
Original impeller part number 375808 superceded by 378891 superceded by 775521 now. (18-3006 here at iboats)
1946Zephyr
Try Sea-Way Marine, in Seattle. They stock a lot of parts for these oldies. You might also find it beneficial to join the AOMCI. That will open a huge venue of parts for your classic
