1953 Evinrude 15 hp 15012 powerhead base gasket
80Spider
I ordered a powerhead base gasket for a 15014/15 thinking it would fit my 15012 outboard. After looking at the base of my outboard I don't think it is the same gasket. The 15014 has a one piece base and my 15012 has a two piece base. If I use the one piece gasket, the back of the drive shaft opening would not be sealed. I may have to make my own gaskets for this. I need to find out what gasket material to use and a picture of the front gasket would be helpful. I am not sure if the gasket is cut to fit around the perimeter or if it is cut to reach the crankshaft bearing/seal area. There is a gas vent hole in the front bottom of the powerhead that needs to be kept clear. Any enlightenment will be appreciated. I can't find anything on google. This is all I need to get the outboard together after restoration
Thanks,
David
F_R
Honorary Supreme Mariner
Obviously it takes two gaskets, 303138 and 302232. Not only that, they are different thicknesses. If you do not replace with correct thickness, you will have trouble with the parts spacing. Do yourself a favor and get the correct ones
80Spider
I ordered them at marineengine. Is it ok to use a sealer on these gaskets?
F_R
Not really required. Remember, the one gets very hot so anything you do put on it needs to be heat proof. I'd simply leave it dry.
