j.tsokatos@hughes.net
Thread starter- Joined
- Aug 7, 2018
- 6
I'm restoring this old motor. Disassembled lower unit to inspect water pump impeller and found it to be nearly new. However the upper seal is confusing. I found this illustration (below) and it represents each of the components I found on my drive shaft, except for the pressed on collar 1.25" down from the top the splines.
Here's the problem. The diameter of the spring, shown in the illustration, will easily slip past the aforementioned pressed on collar - not shown. When I disassembled the lower unit the plastic disc, o-ring and brass washer came out on the shaft, but the spring remained in the housing, just below the crank shaft, and I had to pick it out. By me how they got past the spring?
Either the illustration is incomplete/wrong, or am I missing something? I would appreciate any help in solving my problem.
Thanks,
John
Thanks,
John
