1952 johnson tn-28 water pump
newboatguy12
hi everyone you've all been a great help getting my 1st boat running if i can get it to pump water id be ready to fish. Anyone have any resources for checking or rebuilding the water pump? maybe i'm doing something wrong? i have prop in a bucket of water (not a barrel) motor starts and idles great but it not pumping any water. maybe the intake not in water? maybe motor not deep enough in water to get good prime? i'm not really sure where intake is. any info will be greatly apperciated
thank you
nwcove
Re: 1952 johnson tn-28 water pump
the pump isnt self priming, make sure the pump housing is submerged.
nwcove
id put the motor in right up to the bottom of the transom clamp, but if its above the water pump housing it should pump water.
HighTrim
Yeah as stated, a bucket isnt going to cut it.
If you need an impeller, message F_R
