1952 evinrude impeller
popsmazz1
I thought I read were an impeller for a 1955 7.5 can be used on a 1952 7.5 with mods. how do you modify it? is it the shaft size?
HighTrim
Re: 1952 evinrude impeller
This is the impeller you need, part number 276983
http://www.*****************/newparts/part_details.php?pnum=OMC0276983
The '55 uses a 277181, superseded to 434424 here. The '55 impeller is much cheaper!
http://www.*****************/newparts/part_details.php?pnum=OMC0434424
I believe that should work, as it does with the TN using a newer 5.5hp bored out. I have not done it on a 7.5hp myself though. I have a few 52 Fleetwins around, if I have time Ill have a peek at the dimensions of the impeller.
Chinewalker
I have used the '55 style impeller in a couple neutral clutch Fleetwins. Requires you to thin the profile of the impeller on a belt sander, flipping it frequently to keep the removed material equal on both sides. I don't have the dimensions handy, so use your old impeller as a guide. I believe I had to bore the center out a hair, too, but it's entirely possible I'm mixing that up with another modification procedure. You'll know soon enough if the later impeller doesn't fit the earlier shaft...
F_R
Honorary Supreme Mariner
Brian Wilcox can make you a new impeller. You have to send him the old one because he recycles the brass hub.
Call him at 810-794-7685 before 8 pm est please. Or email Baron0418@att.net. please note the B must be a capital.
popsmazz1
started it up today and pumps water good, the previous told me it had new coils and water pump a few yrs. ago and not used much after, looks like he was telling the truth. thanks for the help.
TN-25
Hey 17ft'r, your model # 6202 is for a 1972 Evinrude 6. Your motor and earlier motors back to 1966 share the same leg; in fact the midsection / lower unit look the same all the way back to 1956. There was a change for 1966 when they eliminated the shock absorber below the impeller and replaced it with a splined propeller hub to accomplish the same thing. Not wanting to allow an earlier non-splined prop to work on a later non-shock equipped 6, OMC purposely changed the prop shaft so you couldn't do it.
As to the original poster (this is a 3-year-old thread BTW) I don't know that Brian Wilcox is still doing impellers, though you or anyone could try to contact him.
