1951 Evinrude 4423 5hp Carb rebuild/adjust
newfiez
Anyone have the procedure to build and adjust the carb on a 1951 Evinrude 4423 5hp?
newfiez
Re: 1951 Evinrude 4423 5hp Carb rebuild/adjust
I have the carb rebuilt, I still need the adjustment procedure...anyone?
Daviet
You have two needle valves, one on top (low speed) and one on the bottom(high speed).
Static settings:
Low speed = 1 1/2 turns out from lightly seated.
High speed = 3/4 tuen out from lightly seated.
Final adjustment should be made with the boat in the water.
samo_ott
The 4423 was a 3.3hp. Made from '47-'51. I have the original operators manual with basic carb set up in a pdf if you want to PM me your email address and request I'll send it along.
newfiez
Static settings:
This carb is different and only has one needle on it for fuel mixture. There is a set screw for the low speed adjustment which controls airflow. I think I may have the fuel adjustments figured out, but now I have a problem with it running for a bit, then stalling, and fuel leaking out of the float needle :confused:
bktheking
Sounds like it needs to be cleaned and inspected, float is probably shot.
newfiez
Maybe. It looks like it's sticking somehow. But it may be possible that it's fuel soaked.
F_R
Honorary Supreme Mariner
Yes, 4423 is a 3.3 horsepower 1947-51 Sportwin.
If the float is shot, you can modify a Mercury float to work. Part number 18-7208, here at iboats.
The float valve has no separate seat. If the seat is bad, you have a problem.
I guess I don't have to tell you what a monster that carburetor is. Good Luck. You are going to need it.
newfiez
You're right...it's a nightmare...
bktheking
F_R- what carb did they use, was it a tillotson? I tried looking up parts to no avail.
F_R
Made by Evinrude. I haven't counted them, but maybe more parts in the carburetor than the whole rest of the powerhead.
bktheking
Very "tillotson" like however on the tillotson you could change the seat.
beverly
Did you adjust the float?
newfiez
This is not the adjustment req'd for this carb ^^^^^. If you look a few posts up, there is a pic of the carb I have. Thanks for trying though.
tjlumpkin
