1946-1949 johnson td 20 5hp
I have a few Q's are regarding the area between the power head and lower unit the main shaft
Here are the 2 little holes in the main shaft going to the lower unit i get water and exhaust sputtering out of there is this normal i believe it may be but am unsure?
then i got a grease leak on top of the lower unit under the adjustment bolt on the left in the pic
the grease leaks out ever so slightly hear between lower unit and shaft ?is there a seal or something right there?
How would i go about fixing this leak?
