Re: 1940 Starcraft
Rivets , but on the sides about a half an inch of metal is folded back almost to touching its self, and the stern has a half inch bent at a 90 ,and slides into the sides and is pressed,or crimped or whatever, can`t tell if it`s welded,spot welded or just pressed, has lead on all the seam`s,very good eye I had to go look again myself,thank you.This boat shows an interesting fore runner of how ours are built. Can you tell us how the seams are held together? I can see rivets on the upper portions but no sign of them on lower hull. The stern shows no rivets unless the paint is hiding them. I have seen stern corner brackets like you have for sale on ebay with the star.
Agree with observation of the shape of the hull. At first I thought canoe inspired but the dory is a better description.
And if you have not painted the exterior you might consider just polishing the aluminum. I am polishing the trim on my Jet and it is gleaming.
Keep us posted with pics. You might look into photobucket to post them. Many of use that service, it is free and fairly intuitive to use.
60 degrees this weekend, going to haul mine out and get back to work in earnest.
Albert
