mlrman
Thread starter- Joined
- Jun 3, 2010
- 82
Hi,
I recently purchased a '91 Sunbird Corsair 198 19' cuddy cabin, pictured in avatar. It has a 4.3 V6 with OMC outdrive. The prop is currently a 14.5 x 19 3 blade aluminum with a couple small dings.
WOT is 4500 - 4600 RPM @45 MPH (speedo) if I bring the trim up on smooth water.....with only me in the boat, and it planes out quickly.
Here's the problem....with three or four adults sitting in the boat, the boat just will not get on plane. I have to have someone move near the front or even get inside the cuddy for it to plane, then we are fine.
I believe the engine is running well, so before I mess with a hydrofoil or trim tabs, do you think my prop setup is correct?
Thanks for any replies.
