18hp Johnson jumping out of gear
Roger60
Had to get a new account could not get my old one back. Motor jumps out of gear when throttling up. Have read some of the files on fixing this and tried to adjust the shift linkage today with out success. This is a 1959 Johnson 18hp I have reworked everything on this motor except the lower unit. My brother uses boat its at his house on the lake. He told me today that he did not change the lower unit lube this year until this week. When he put the new lube in nothing came out when he took out the screws to fill it. He has had the boat on the water since April. I am afraid he has damaged the lower unit gears and the shift dog? Any suggestions before tearing the lower unit off to look for issues. Are there parts for this repair? Is it worth repairing?
lindy46
Nothing? No water? Maybe he forgot to refill the gearcase the last time he drained it. If it was run with no oil, the gears most likely are damaged. Take the gearcase apart and inspect.
HighTrim
Yeah time to open her up. Will be cheapest to find a donor gearcase.
Roger60
Is there parts available for purchase or do I need to find used parts for repair?
lindy46
New parts are available, but pricey. Best to open her up and see what's damaged.
Roger60
ok will do, is this motor worth repairing? Where do I shop or find these parts?
82rude
The bay or c list are 2 starting points.If you get extremely lucky and theres no damage a clutch dog is still available new from brp of various sources online.,maybe even here at iboats.I got a brand new dog for a 56 30 hp Johnson from brp a couple of years ago and it wasn't that pricey.Mind you everything else is either nla or very pricey.Theres tons of those old motors around you should be able to find a donor easily enough if need be.
82rude
1957 was the first year I believe of the 18hp and went into the 60,s.I believe all were the same except for cowling design and fuel pump change over.Its totally up to you if its worth it, but if theres a better made outboard out there id like to know what it is.IMHO the 5 1/2 and 18 were 2 of the best outboards ever made by anybody period.
Honorary Supreme Mariner
Found 3 of these gearcases at an ---aomci ---flea market.------One even had the ultra high priced front bearing / gear update.----Paid $30 each.--Gearcases up to the 20 / 25 hp models of 1976 will fit the older motors down to 1957.
Roger60
I just need a website than can provide the parts I need. What is the bay or c list??? I will be tearing down motor this week if I can get parts for 250.00 or less. I will also need a seal kit for the lower unit I think. I just want this to be the fix for motor jumping out of gear.
I like to fix old motors the 55 5hp I have just will not push the Cubtoon.
82rude
ebay or craigs list.like has been said some parts are no longer available(nla).
scottmm73
Without breaking terms of agreement, think of two popular or common online yard sales or garage sales.
Roger60
Ok got it now I am new at this computer stuff. Thanks for the help.Will update when I open the lower unit.
82rude
If were not suppose to mention the 2 sites I mentioned I'm sorry.
Roger60
I have found some parts (I Think) for lower unit but not sure of the part numbers, Looking for Forward and reverse gear, clutch dog, and Pinion gear.
What are the correct part numbers for a 1959 18hp Johnson FD-13R Serial # 1990846? Are some of these parts interchangeable with different year motors?
hardwater fisherman
Clutch dog is 0305191. The forward and reverse gears, and pinion gear can be bought as a set. The part number is 0377877. The clutch dog costs almost as much as the 3 gears combined. Check here first to see if they have these. If not google those numbers to find where they can be found. EDIT Have you opened up the gearcase or are you just curious on price?
Roger60
Thanks for the info. Opened up lower unit today Broke the plastic hub that holds the prop on,need to find a new one of those. Could not get the drive pin out of shaft .Not sure if there was maybe a outside clip that broke off and the ends were just sticking into the shaft?
There was a small amount of fishing line wraped around shaft when I removed the prop. After looking at the inside parts the gears looked great the clutch dog looked a little worn on the edges. The thing that caught my eye was the sleeve that the forward gear slides into was very worn and cracked. This part definitely needs replaced. I may need that part # too.
Will show pictures when my brother sends them to me. (I do not have a smart phone.) If I can figure out how to do that. The bushings looked clean and smooth on the inside of the gears. Pinion gear looked great. One of the bolts holding the lower unit on was broken off. Got it out no problem. I ordered a seal kit for the lower unit today. Not real sure where they will all go.Will update with photos ASAP
Roger60
No Title
Here are the Pictures that I have from lower unit teardown. Front bearing looks bad. Gears look good. Not sure about Clutch dog??? I also included picture of Prop are where I could not get the pin out. Can I drill it out? There is another hole 180 degrees on shaft that could be used?? Ordered new seal kit for lower unit but not sure where all the seals go some my gone completely
Roger60
Just ordered parts I think I need (bearing,clutch dog,) for lower unit repair. Got a plastic prop hold down cap coming too. Hope to have it back together this weekend.
jimmbo
What about the gears? If the clutch dog is as badly worn as yours is, the corresponding spots on the gears may also be worn. You say you ordered a bearing, what about the rest of the bearings? They were all run without oil. Did you ever get the drive pin out? You said there was fishing line wrapped around the shaft. a very common reason for propshaft seal failure. You need to replace that seal, so that drive pin needs to come out. Then you can remove the prop shaft from the bearing housing and check both for damage. Plus you will need an o-ring for the bearing housing and an new spaghetti seal to reseal the two gear case halves. Now we come to the drive shaft bearings...
