I've have been getting water in the lower unit of my 18hp seahorse. I have replaced the O ring, half seal, seal the prop shaft goes though and I'm still getting water in the lower unit. It looks to me that it's not the best design because the six screw are on the inside of the half seal. The only other thing that I havn't checked is to see if there is any seals around where the shifting rod and the shaft that turns the gears. Is this a common problem with this model motor. tanks for any info.
