18hp johnson damaged spark plug
okelley77
Re: 18hp johnson damaged spark plug
Play in the needle bearings on the connecting rod, letting the piston travel to far up the cylinder wall.
lindy46
Or wrong plug with too deep a reach.
1946Zephyr
Yes, I second that. If you use Champion J6C's then you won't have that problem.
boobie
What plugs are in it now? If you have J6C's, you have some internal probs.
Cofe
If the plugs are J6c's you might have excessive carbon built up on the piston. You can remove the spark plug and turn the motor over by hand, and use a flashlight to look at the top of the piston when it is on top dead center.
F_R
If you have the correct plugs, DO NOT run that motor till you find the cause of the problem. It probably is about to scatter its internals all over the place.
wifisher
Have you ever had this happen? While the engine is running, carbon will not gather in areas with interference. It will find a different area to grab onto.
Cofe
I have seen it happen on a motor with weak/intermittent spark on one cylinder.
nathangormley
Thanks for all the advice so far. I will check to see if they were the correct spark plugs after work/school. Lets assume for now they are the correct plugs and there is no way the gap could be flattened by over tightening.... What should start doing next to fix this problem? I will look at the top of the piston with a flashlight and post what I see tomorrow. Thanks in advance.
F_R
Well ok, getting ahead of ourselves, If it has the correct spark plugs, then stick a screwdriver into the plug hole and slowly turn the flywheel, following the piston up and down with the screwdriver. Just follow it, don't push.
When the piston is about half way down on the downstroke, stop turning. Then give a light push on the screwdriver. If it moves with any appreciable amount, and gives a clunk, you have serious trouble inside. In that case, the powerhead has to come apart for inspection and repair. There is no other way.
nathangormley
So I checked when I got home last night and sure enough....wrong plugs. I appreciate all the advice even assuming that it may have been the correct plug. I did not have time to do any further inspection so now the question is if there has been any damage done to the piston?
kbait
I've seen the same thing happen w/no piston damage. Motor ran fine w/correct, shorter plugs.
kfa4303
Banned
you should be fine. no major damage done.
boobie
Let us know how it runs with the correct plugs in it. By the way, what plugs did you have ??
1946Zephyr
I had this issue with the NJK's, but they soon fixed the issue by re-designing the plugs with a shorter thread shank.
If you were able to pull start the motor, before the pistons slammed the gaps shut, then you won't have to worry about damage to the pistons. Fortunately, they only hit hard enough to close the gap.
nathangormley
The plugs that were in it were champion 828. Which the champion JC6 is also CHA 823. Or atleast thats what the guy at O'rielys said.
wifisher
Never trust a saleaman's cross reference.
Just sayin'
boobie
I don't trust salesmen, period. Anyway, did you ever take the J6C and measure the length of it against the plugs that were in it???
Steve A W
You might want to do a compression check.
Steve A W
