OK, sorry to have to ask, but I am at my wits end here.
Buddy has an 18202R 1972, we started it after a many year hiatus and got it running, but it coughed and sputtered. So, I went through it, tightened up the stator plate, new points, plugs, condensers, coils are good and it gets good spark.
Pulled the carb, cleaned everything, made sure the holes in the bowl gasket lined up, etc. reinstalled and timed the carb to the timing marks on the flywheel.
Engine starts and idles without coughing and sputtering, but that is about all I can say for it at this point. it idles and runs against the shift stop, and a little lower, but not like it should, basically it acts like it is not getting fuel, if I manually play with the throttle plate I can get the rpm to come up a little before it chokes and dies, if I put it in gear, it will run, but as soon as I try to increase RPM, it coughs and dies. fuel lines are clear, blew through all of them, pumped the ball with the fuel filter off, fuel sprays out, pump the ball with the carb disconnected, fuel sprays out.
The low speed adjusting screw is only about 1/3 of a turn open to keep it idling smoothly, but like I said, it is idling very slow.
I am pretty sure the points are right at .020, checked them twice, but can double check again, maybe the slipped open a little.
Fuel pump looks intact, no leakage, I have disassembled and reassembled (after this problem started) and no difference in operation. The diaphragms in the fuel pump seem stiff, not soft and rubber like one would expect.
My next steps are to put in a clear fuel filter between the fuel pump and the carb to see if fuel is flowing, but, even pumping the bulb does not seem to increase rpm, maybe a little, but, not much.
This motor had a higher RPM when it was coughing and choking against the stop than it does now. like 4x faster but it was coughing and choking, kind of like what it does now if I try to throttle up.
I am thinking fuel pump is weak, but why did it idle higher before the tune up and carb clean than it does now? is it possible the float is just sticking? there is no spring clip on this needle (none in the drawing either), the carb is a simple one, not many moving parts, and I made sure I could blow through every port, including the high speed orifice.
Any other ideas and things to check would be greatly appreciated.
Dave
Dave
