ezmobee
Thread starter- Joined
- Mar 26, 2007
- 23,767
Re: 18' Starcraft SuperSport restoration
I did not pre-drill the rivet holes. I figure it will be covered with glass after being installed so that would be kinda overkill. I was planning on pre-drilling my transom holes but had forgotten until you just now reminded me
So I will be doing that tonight probably. I saved my drain tubes in order to find replacements but they are pretty well shot. I haven't found any specs on the aruco ply. I did read on here that it may be a softer wood or something and not as good. However! it seems to have way less voids than the regular exterior ply I used for the deck. If you seal it up real well I'd definitely recommend it.
I was just wondering, Did you pre-drill the rivet holes in the deck?? I am going to do that before I epoxy coat it. I figured on going 1/32 to 3/64 over size. Did you find any spec's on the ACX acuply plywood for glue?? I went to there web site and all I found was a bunch of run around when it came to what type of glue they used as I never found any thing in concrete!! I guess I am really cautious on this as I know exposure 1 glue does not hold up. I opted for APA ratings. Do not forget to pre-drill your transom drain holes in before you epoxy!! Speaking of drain holes, Did you save your drain tubes or are you going to replace them??
