Re: 18' Starcraft SuperSport restoration
Little bit of an update. As I mentioned previously I got the old transom out.
Here it is. Pretty wet and rot starting. Good thing I decided to go ahead and replace it. Doesn't appear have been properly sealed.
Yesterday I went and picked up a sheet of plywood for the new transom. Ended up buying a sheet of that ACX Arauco plywood from Lowes simply because I was by myself and the top 4 sheets of the regular BC stuff were warped to heck and it was worth the extra $3-4 to me to not have to lift them off
Seems to be very nice wood. I got both layers of the new transom cut out, matched up and the edges sanded for a closer match. I haven't test fitted it yet as the boat it pretty well smashed up against the back wall of my garage and I didn't feel like moving it out.
I used my new heater for the first time yesterday. It worked pretty well considering how FRIGGIN' FREEZING it was outside. It took the garage from 34-54+ in the hour or two I was out there. I'm pretty confident that with a little more time and perhaps a little higher starting temp it should be able to keep the garage warm enough for epoxying.
Wired a new 30A 240V circuit in the panel (which is conveniently in the garage). My first time working in an electrical panel. I felt the best way for a newbie to tackle this was to do it with the power on.
I didn't die and it wasn't very difficult.
I ordered my epoxy just now. Hopefully it arrives soon so I can start getting this dang deck put in.
