Re: 18' SupoerSport bowrider restoration
Mac,
We did the tear out and re-flooring before I found Iboats; hence, no photos of that. What you will find are aluminum stringers running fore to aft with rigid flotation placed in the cavities. It may be waterlogged but take it out carefully to keep it intact and dry it out. This original stuff resists melting in the presence of gasoline. It will absorb fuel but I did not have that problem. Mice got some of it.
I found 1" coated, self-tapping screws with a flat countersunk head and a hex drive at Fastenal. They mounted flush, resists the galvanic corrosion, and chemicals in PT plywood, if you use that.
I'd like to see your progress, as you go along. All on Iboats are starved for boat pics, next to pin-ups.
Thanks for the quick response.
I am very interested in relocating the fuel tank in the center of the boat under the floor, like they do in newer boats. This will help to reduce weight in the stern a bit.
With what you remember, do you feel there will be room for a long tank onder there? I will fabricate the fuel cell myself, so I can make it almost any shape. Was there a stringer in the center of the hull that would preclude this? If not, how far appart would say the two stringers were. How wide of a tank could I make to fit in there?
Lastly, I won't be using PT plywood. Even though the new stuff doesn't react with aluminum like the old creasote stuff did. I will use standard plywood and seal it with an epoxy. The final floor will be an epoxy coating like they use as truck bedliner material.
Here's a few pictures of the boat as it exists today -
I'm also unsure on the motor. It currently has an 85hp Evinrude on it. Old, and runs a bit rough. But it starts and will push the boat with a full tank of gas and 2 big guys to 34mph per the readout on the GPS. Also, the unit doesn't have trim and tilt. I really need this as the bay we run from is very shallow and has a lot of rocks in it. (don't ask
I like the Yamahas because they are so light. I really would love a Yamaha 90 to put on it, but the cost of one is quite high. Kind of tough to justify it on such an old boat.
But I have a line on a 93 Yamaha 70 hp outboard that is in very good condition for a reasonable price.
I am a little leary though. I am not looking for a high speed boat but I have owned far too many under-powered rigs. And I am afraid the 70 might not be enough. Anyone out there running a 70 hp outboard on a 18' Starcraft that could shed some light here?
Thanks.
Mac
