- Oct 25, 2011
- 25,242
Re: 18' Holiday OB ~ the Backburner project
I also grabbed a nice piece of aluminum angle off the transom lip of the 1350's donor boat.
So, now 1350 Merc info is here, where it belongs.
Wow, nearly 16months between posts......
Got to spend some time on the beast tonight. It put up a little fight, but the steering has been removed from the tilt tube:
The boat had to give up some more glass to accomplish the task:
Little by little.
I'll finish getting donor 2 cut up in the next day or 2, then get a little help lifting the beast off the transom. I'll need to bleed the T&T system, it's stuck tilted up as well.
Have a great week...................
Thanks for swinging by Decker, appreciate it.
So, I'm having trouble getting the remote cables unhooked from the motor, so I'm going to ME.com & find a Merc remote parts diagram & see if I can get a better idea of how to pull them off. It wasn't even evident to me if they were cotter pinned or thru bolted in some why.
All the trim pump hoses & wiring are free from the hull, just not ready to unscrew a line & possibly drain hydraulic fluid into the hull, just yet. I've also cut back more of the splashwell so I can access the lower engine thru bolts. OB still doesn't have much give w/ that big Merc hanging off it, too bad it was such a wreck. Could have been a nice 17ft bow rider.
Engine cherry picker is broken down at my office, so tomorrow's task after work is it's transport & set up on-site, then get the motor control cables all disconnected. IF it all goes well, perhaps lift the 1350 off the transom.
My backordered rivet gun arrived:
I may just need to bring a better over head light & a flashlight, unless I get the motor tilted back down, it's just an awkward angle from inside the boat or standing beside it.
W/ the motor upright, it'll be much easier to be standing besides the motor looking down.
Didn't find any info for the trim pump either. I'll look today & see if it doesn't have a bleeder on the base somewhere. There isn't much of a reservoir, it seems to be the base of the pump assembly.....
This may prove helpful:
For 4 hose T&T systems ^^^
And the 1350 has 4 hoses.
7/16" nuts & bolts were holding the remote control ends. And yep, had to crack the fluid lines open to get the trim rams to drop. But drop it did. And it's free of the transom
If only temporarily.... Some jack leg forgot to build the OB stand...... Doh...
