18' 1987 Winner Cc
Brandywine
I recently purchased this great boat, and we just fininished restoring her looks, only to find a gunked up fuel tank. The mechanic at the yard wants to CUT THE TANK OUT of the boat to clean it ??? !!!!:eek: Wouldn't a complete flush and a Racor filter do the job ? Why would the boat need an operation ?
Has anyone had a problem with the new ethanol gas in the old poly tanks ?
Please advise
studlymandingo
Re: 18' 1987 Winner Cc
The poly tanks are a cross-linked polymer plastic; there should be no issue with ethanol. If yours is gunked-up it would most likely be from gas that was left in there long enough to turn to varnish. You could probably flush a lot out with a cleaning, then run through a couple of filters.​
Brandywine
Well that sounds a little more promising. Is it a 36 gal or thereabouts tank, and are there baffels in it ? Is there any access to the tank at all ? Can the hoses be replaced ? last night I ordered a 32OR-RAC-01 racor filter with a couple of spare canisters. I'll do a good flush on the tank, hopefully be able to get at the hose to replace it, and mount the filter. This filter has the clear bowl, so I'll be able to kep an eye on it. Thanks ------ Bill
studlymandingo
The tank I replaced was a 60 gallon aluminum tank, I put a 55 gallon poly tank in its place. The new tank I have does not have baffles unfortunately; no rotomolded tanks do. The entire deck below my center console is a hatch for the fuel tank.​
Ken Barber
Bill,
I bought mine with a gunked up tank as well. I did not know what was in it, but here is what we did to fix it -
While the boat was on the trailer, I parked it on a hill and ran one wheel onto a car ramp (the kind you use to change the oil on your car). This put one corner of the tank in the lowest position.
On my 89 18 footer, the tank access is throught the console seat. I took out the sending unit, which gives you a hole about 2" diameter to work through. I bought a cheap fuel siphon from the auto parts store with about 5 feet of clear hose, and added some more clear hose to it so the oultet end was below the tank.
I used a clothes hanger to fashion a guide for the other end of the hose that would get and keep the other end of the hose right in the low corner of the tank. I measured outside and wired the hose up to the coathanger contraption. I wanted to get ever last drop, so this was better than just sticking the hose down the hole.
Sounds like a lot, but with my buddy outside of the boat working the siphon, and me holding the other end directly in the low corner of the tank, we sucked out 15 gallons of contaminated fuel and gunk. (takes awhile!) You could also spring for a more expensive fuel pump if you do not want to wait for the siphon. My fuel had a lot of water and other crap in it that we watched slide down the transparent plastic tubing of the siphon.
I added the same racor, ran it around for 45 minutes, emptied the racor of anything that came from the lines, and it has run primo ever since. I think you are pretty close with your 36 gallons with the poly tank, and that it is the original tank.
Hope this helps, good luck
Ken
Brandywine
Ken,
Thanks for the positive info. i get home on D Day, and I will be bringing the boat to the house where I'll tackle the job. I'll let you all know how I made out. By the way, Bean town and the Purple Shamrock is the best! later --- Bill
