175Hp johnson oceanrunner turn key and nothing!
Hotpursuit26
Hi, I've tried everything. I turn key on starboard motor and nothing. The guage needle doesn't even move. It ran fine over the weekend.Checked batteries,cleaned terminals, tightened terminals down tight. Checked all fuses on motor. It has power to the motor. I even changed ignition switch. Traded off power pack from port motor no help. Anyone? Got anything that i missed that would help.Thanks John
boobie
How about the neutral safety switch in the control box ?
Hotpursuit26
Thanks boobie! Never knew there was one! Im going to the boat tommorrow. I'll see if i can find it. I'll let you know. Thanks again.
Hotpursuit26
Boobie, I know that if the control isn't in neutral it won't start. There brand new i had a mechanic install them a couple of months ago. In the case of the switch are you saying it could be shot, or is there a reset or something? A hint on where i could locate the switch? Thanks John
Chris1956
Honorary Supreme Mariner
Gee, if you have no power to the gauges, either the main fuse is blown, or a power wire broke somewhere. What year is the motor?
bob johnson
there is a shift interrupt switch on the motor at the end of the cables...it could be poorly adjusted or bad.....
you could take the harness from one control and hook it into the other control.....and give that a try....that will give you information
bob
