175 Johnson Tilt/Trim Seal Kit 1995
Dieselpowerman
Does anyone have the correct part number for a tilt/trim seal kit for a 1995 Johnson Ocean Runner, 175HP? The main piston seal is leaking on mine.<br /><br />Are these the kits I need to be looking for?<br /> Seal Kits <br /><br />Thanks in advance.<br /><br />DPM
93bronco
Ensign
Re: 175 Johnson Tilt/Trim Seal Kit 1995
oring seal kit # 434519. last price i was quoted is $55.00
Dieselpowerman
Thanks for the help with the part number.<br /><br />Does anyone have any comments on the difficulty of this job? It doesn't look too bad.<br /><br />DPM
clanton
You may be able to buy just the seals you need, instead of complete kit.
Dieselpowerman
That's true. All I need is the seal for the tilt cylinder end cap, and the o-ring (or seal) for the piston.<br /><br />Where can I get these part numbers? Does OMC make a CD-ROM with parts explosions and numbers like some companies do for automotive engines? The local dealer I have talked to has not wanted to divulge any part numbers to me.<br /><br />DPM
