175 evinrude lower unit
reef donkey
I have a 1997 175 evinrude ocean pro change the water pump and i remove the pump housing and the drive shaft moves like a bearing is going out with the water pump off is this normal for the drive shaft to do this. THANKS!
jonesg
Re: 175 evinrude lower unit
"is this normal "
Only if you plan on running it without the pump housing.:)
