175 evinrude loss of power at acceleration
surfguru
I have read most of the post but am still confussed as to what the problem might be. It seems to run fine in idle and when I put it in gear but as soon as I begin to plain out it bogs down. I recently replaced the VRO because the alarm was sounding on throttle case. I found a crack on the back of the old VRO pump but since replaced there has been no alarm. I checked spark plugs and found they were dark black. I am going to try and clean the jets and see if I have any luck. I ahven't really run the boat since last summer but have started a couple of times this year. Any help would be appreciated!!
jim dozier
Re: 175 evinrude loss of power at acceleration
Put it back in the water and do a few more tests. You've replaced the entire fuel pump, yes? Verify that your gas tank is picking up gas by pumping the bulb when it bogs down, bulb isn't collapsed is it? Try choking it when it starts to bog down, does that help (if that engine doesn't have a choke squirt some premix in the carb throats when it bogs down)? If so it is running lean on the main high speed jet probably due to a gummed up carb. I would think that would be your case, however you mention that the plugs were all black which sounds like a rich condition. But since you haven't really been able to run it out I'll say the plugs (replace them) are just a red herring and go with fuel starved high speed jets. Be thorough in your carb rebuild don't make them pretty make them carburate.
surfguru
Thanks Captain. Cleaning the Jets worked wonders. Boat is running like brand new!!
