170 Alternator conversion
Redkneck
So I'm only getting 12.6 volts running the OEM setup. Going to make a bracket and install an old delco 10/12SI one wire setup. Im guessing I can just unhook the water cooled regulator and tape up the connections to disable the old system?
Where in my harness can I hook up the #1 terminal to get the indicator light, or just disregard it?
Thanks as always!
john
Redkneck
Re: 170 Alternator conversion
Thanks Eric! I'm a little confused on that schematic though, shouldnt the Batt terminal on the alternator be full-time to the battery? Looks like it's attached to the start terminal of the starter solenoid or am I missing something?
thanks, john.
Don S
Alternators are always wired to the starter like that on an OEM marine engine. No need to go directly to the battery. If you have a battery switch, the alternator wouldn't be disconnected from the battery when you shut the switch off.
The only time you would go some where else is if you had a battery isolator. Then the alternator would go to the ALT terminal of the isolator.
wrestling coach
Here is an example of a low mount conversion on my 470.
Dennis
The alternator output goes to the same terminal on the starter as the positive battery cable. The battery is charged thru the positive cable.
