17' 1969 Powercat porpoising
kpbulldog1996
I've got a 17' 1969 Powercat that I'm refurbishing. I've put a 1979 Mercury 140hp engine on it with what I believe is a 19 degree Johnson prop with Mercury hub. The problem I have is that the boat porpoises at virtually any speed and trim combination. Any suggestions as to what the problem is?
Cadwelder
Re: 17' 1969 Powercat
Welcome to the iboat Dry Dock.
I don't think this is the proper place to get your question answered. You'd be better off to post it under props.
steelespike
Did you work on the stringers and floor?Replace the transom? Is the boat rated for 140?Is the motor mounted as high as possible on the transom?
