Re: 16HP WESTBEND
Hi Bruce,<br />That motor only had 90 lbs of compression<br />when new so it may not need to be rebuilt.<br />I've never looked for parts for one. Major<br />parts will be hard to find. I may have a waterpump and seals. Points & condencers,but<br />no pistons,rings, or rod bearings for the powerhead. No gaskets either. On the bright side I should have carb parts and ing parts<br />along with the pump. Also I can get you a copied manual If you need it. I'll look for <br />some major powerhead parts also,but I hope you know where to et them.<br />...have fun...corm
