hey guys. Old faithful started giving me fits yesterday. Ill try to give a run down on the situation and ill let you guys decide what the best course of action would be as im sorta stumped at the moment.
i have a 71 19ft trihull boat with a wake tower. it has a alpha 1 outdrive installed with matching gear ratio. and,, ive had these symptoms happen before with the original drive. it has the 165 inline 6cyl 250cu 4.1liter.
New carb rebuild.
new alternator.
new balancer and belts.
Boat ran awsome! got up to speed faster than ever after i got the carb rebuilt. turns out it has the wrong accelator pump installed.
anyways 2 days ago we went out wakeboarding with 5 people in the boat and i noticed the power started falling off twards the end of the day. at the end of the day it was taking about 4 times as long to get on plane. And would only run to about 3000rpms in gear. it would rev freely out of gear. and wot is around 4100 ish depending on the how many friend are with me when the boat is running correctly.
anyways the next day we took it out and it ran better for the first 10 minutes. then everyone showed up and i had 6 big people including myself in the boat and could barely pull a wakeboarder up. took along time to even get past 15mph once the boat would plane then the power was fine.
It got worse and worse till the boat would only do 15mph tops and wouldnt plane out.
all the guages were showing ok numbers. motor didnt seem overly hot. although i could be wrong. however there was no hot smell in the air.
It did do this once before last season and went away on its own. i could never find the problem cuz it ran fine after that horrible day of idling 10 miles to the boat ramp.
i put the boat in neutral and reved it up and it would free rev to 5000 but seemed sluggish. the water hose before and after the thermostat was cold. which i thought was wierd. but figured it meant the water pump was flowing water good.
um... about the only other things ive done to the boat is new cap and rotor and wires and plugs last season.
i did cut the resistor wire going to the coil when i first bought the boat not knowing what a resistor wire was. however i soldered and shrinktubed it back together. dont know if that would play into anything or not.
i installed a new fuel filter last month.
And off and on the boat has had a wierd problem of kinda surging. the tach would be real jumpy. you could feel the boat run good, then drop off then pick back up. sometimes it would drop for only a second. othertimes it would be for 10 secs were the power would cut to like half.. then instantly pick back up.
I almost feel like its a coil issue, a mechinacal advance failure, or possibly a fuel related issue.
however i dont have a service manual and dont know where to buy one locally.
if i could buy one online in pdf format that would be great.
Or if someone wanted to send one to me would be awsome.
any thoughts?
many thanks, Drew
New carb rebuild.
new alternator.
any thoughts?
many thanks, Drew
