Stasik
Thread starter- Joined
- Mar 18, 2012
- 38
Folks, I thank you for the future advises!
Almost ready to brake down...
A few month ago I Took my boat (older tri-hull, 21 ft with 160/6 cyl mercruiser) to the ocean for another fishing. On the way back I went crazy and tried to see what it can do. Got maximum speed out and blow the impeller up. Somehow I got back and at home, sure I changed the impeller (all kit with a new cup), then pickup tube between the two halves, then water pump. With muffs on it's working fine. Not overheating for 20-30 min. RPM 1000
Took the boat to the lake to check - overheating after 15-20 min with 1800-2000 RPM
Changed oil and filter - it was old, and run it for 30 min at home with muffs on - it's working fine for 30 min on RPM 1000.
Took it back to the lake - overheating after 25-30 min on RPM over 1800.
Just in case, I changed gas filters and sure, no changes.
I can't think of anything else to be changed.
I just do not want to believe that I could damage the engine.
Any ideas, what else to check what can I do to fix this overheating?
Best wishes to you all!
