ChaseMaine
- Feb 8, 2011
- 25
I just bought a 1984 16' sea nymph, I believe it is a fishing machine.Found it on CL and bought it for $800. The boat came with a 45hp mercury classic 50, which I was told runs but we'll see. It also came with a bow mount 42lbs of thrust minnekota trolling motor. The previous owner replaced all the decking and carpet last year and looks like its in good shape. I ripped up the old vinyl on the floor and noticed that half of the deck seemed to have been replaced at some point but half hadn't(the rear flooring). So I ripped up the rotted boards and replaced them with plywood I coated in sytems 3 resin, then riveted them down. I already ordered new nautolex marine vinyl from defender marine, looks like good stuff.
The boat has a livewell that had been plugged and disconnected, the pump is still in the transom and the thru-hull overflow is just plugged. When I took the livewell out I noticed 3 holes in the bottom of the live well, one about 1/2" wide and the other two about half that size. The holes were also drilled through the deck to the below the deck? I want to re-install the livewell and its my understanding there should be a fill hole where the water gets pumped in, an over flow, and a drain. So should I plug the two smaller holes and use the 1/2" hole as the drain?
Another thing I need to decide is where I am going to put the live well, I can put it back where it was and mount a seat on it in front of the console, does anyone have some ideas or maybe have mounted seats to live well covers before. The livewell is pretty long and I was thinking of putting the hatch on the opposite side of where the seat would be mounted .
I am not sure yet, any ideas is appreciated. I can't wait for warmer weather so I can work on the project more. But were supposed to get 5-10 inches here in maine on thursday!#%
