16 1/2 Aluminum Tiller Prop issues
tomcan
Hi, I have a 16 1/2 aluminum tiller boat. Loaded, its over 2000lbs. Dealer suggested a 60hp mercury command thrust. So that's what I got. Dealer says they tried 2 different props and the 1 they put on is the best for my application. I'm not so sure! First of all, its a 13p spitfire which they say will only rev to 5500 rpm. I think maybe the tach is off because I did the calculations and top speed with zero slippage is 29mph, which Is actually what I get on gps! I think it must be revving much higher than the tach says? Any thoughts?? BTW, its a 2.33:1 gear ratio, if anyone wishes to double check my math! Either I'm doing something wrong, or the dealer is out to lunch!
Sea Rider
Welcome to Iboats,
That OB should have a rev limiter, if doesn't kick in while at full hammer down as loaded, don't worry..
Happy Boating
