15hp rude 1974 spark issues when warm
joelster
Im trying to upgrade to a 1974 15hp evinrude ,
horrible video shows bottom plug sparking on outside from spark plug wire to hex part of plug , especially after running 1 min ,
new plugs ngk (old plugs did same thing champions ) gapped .030 , new coils (old coils did same thing, they were cracked and epoxied over), wires boots, changed one condenser same issue , then changed the other one ,I had only bought one new one.
, cleaned /sanded points, re gapped .020 best of my ability, sanded coil ground wires , ( non electrical work ive done , lower unit seals , carbs rebuilt.
thought the condensers would do the trick,
what gets me is the top cylinder works perfect 100% , the bottom works good one minute, then starts sparking on the outside and engine runs on one cyl all of a sudden.
so It goes perfectly for a little while , then half power all of a sudden with in a minute .
https://www.facebook.com/video.php?v=10203819057542159&l=8737948329323168090 ,
any help would be great,
any one seen something like this before?
close to giving up , been trying for months
my next step is to buy a complete assembly under the flywheel .
, maybe convert to newer ignition? how many$$
boat is a 10.3 pelican polyethylene , great for one person fishing, not so good for 2.
I love points on my 9.5 evinrude 1967 most reliable outboard ive ever had , just wont rev to 6000 rpm, or plane 2 people and gear consistently.
​thx !
Bosunsmate
You arent putting anything on the sparkplug threads are you? Are the threads in the head rusted up?
F_R
Honorary Supreme Mariner
Whoa, if it is sparking to the hex of the plug, the boot is not doing it's job. That has nothing at all to do with the rest of the ignition system. You seem to be indicating you installed new boots. That should cure the arcing problem. Apply some dielectric grease inside the boot.
AlTn
looking at the parts diagram for your ignition < should have earlier, but didn't >...the grounding wire for the lower coil...are both the terminal and the spot it grounds to on the block, shiny clean?...are you using a star washer to get a cleaner ground?...the diagram shows a zip tie squeezing the boot onto the ignition wire...are you using one?....that's some real discharge you have in your vid...seems almost constant?...some dielectric grease, as FR noted, and a zip tie to seal it in may or may not work...worth the try.
bwkre
Like racerone says. But I would take it one step further. Sounds like you have some carbon tracking on the boot and maybe even the plug insulator. If you change one without changing the other you could carry the problem forward and damage a new boot / plug. The cycle could repeat itself. Check the plug & boot closely for carbon tracks (google it). I believe the coils have the wires permanently attached but the boot should be replaceable.
joelster
ok ill change the boot, maybe swap with the top one . and add dielectric grease, zip tie , was going to swap the coils to see if the problem follows the coil ,wire and boot,
seemed like it had the same issue with the previous coil ,wire and boot.
the ground to the block looked like it had a nylon or plastic washer between the bolt and block , so the ground charge must go through the bolt .
I will update with in a few days,
thx a bunch!
joelster
i cleaned the carbon off spark plug put dielectric grease, zip tie , and still same problem, swapped the top and bottom spark plug boot and the problem followed the boot , should have been my first step a year ago when I got the motor.
ordered one boot today , and will follow up when I finally get to lake test it, $100 in coils , removing flywheel , condensers,messing with points, hours of fidling around and its a $4 part, figures. im sure changing those parts didnt hurt.
when this motor is dialed in I will be one happy camper,
thanks for all your help , almost gave up on the motor
joelster
question , they show two boot part #s , 581027 , and 580339 , I bought the 580339, not sure its the one,
64osby
The parts manual shows 581027 as the original part. Not sure if it will really make a difference.:confused:
joelster
I made the boot fit ,motor runs like a champ , nutz 15hp on a 10.3 pelican ,I appreciate all the help !
joelster
No Title
thx for helping me get to the SPOT!
