15hp Johnson will not start. I've tried everything I know
okie jess
Thanks for having me here on I boats. My problem is this, sure hope someone can help. Going down the river and it slowly died. Tried and tried to start it back...got in home and I've got great spark, and fuel. Cleaned carb. Tried putting mixed fuel in cylinders and carb manually and nothing. Feels like I've got great compression on both cylinders. Can someone please share some light on this. Thanks
F_R
"Slowly died" would sound like it ran hot. Did it? If that isn't it, the rules haven't changed. It needs enough compression, fuel in the right amount, and spark at the right time. I don't know from here which you are missing.
okie jess
15 hp Johnson will not start. tried everything I know
Thanks for having me on i boats. I hope someone can help me for I'm struggling. Going down the river and motor slowly died. Couldn't get it to start back. Get home and Im getting great fire, and fuel. Cleaned carb. I've manually put mixed fuel in the carb and both a cylinders and nothing. Feels like I've got good compression. I'm lost. Can someone please share some knowledge on this.....Thank you.:)
Model # is ?-----Are you mixing gas and oil at 50:1 on that motor.----Is the waterpump impeller working properly.---Report the results of an actual compression test !
okie jess
I don't think it got hot. How would I make sure I'm getting spark at the right time? And wouldnt it still fire if it was a fuel issue by manually putting fuel in carb and cylinders? Thanks for any help for I'm not much of a mechanic
okie jess
Model # is 15R750. Gas is mixed 50:1. Water pump was working. I will have to get a tester before I can get u a the last part.
Does spark jump an actual gap of 5/16" or more.--If you had a blown head gasket then the motor would not fire.--Sheared flywheel key may be an issue here.
okie jess
I've got the flywheel pulled off, what am I looking for in the case of a sheared key. I know sounds like a dumb question but I want to know I'm doing it right.
boobie
If the key is sheared it will be in two pieces. One in the flywheel and the other in the crankshaft.
Bosunsmate
Flywheel key is the half semicircle thing that should be sticking out of the top of the crankshaft just below the threads for the nut
steelespike
Sometimes the key is partially sheared it still throws off the mag timing.
Sometimes the keyway in the shaft or flywheel is distorted.
The purpose of the key is to position the flywheel The torque on the nut holds it in place.
If you got the nut off with little struggle it may not have been torqued tight enough.
Nut torque is 40 to 50 ft lbs.
okie jess
Okay, key looks good. I forgot to mention earlier that I'm getting a good 7/16 spark off my plugs...so torque wrench set at 50lbs.....I will go get a compression tester in the motning. Thanks for yalls info, I sure appreciate it.
glust
Could just be a bent flywheel key. I've seen them tugged far enough that the timing is off enough degrees to prevent combustion. Usually something brings about this change rather quickly. OP describes the motor slowly dying. I'm thinking heat. He might be confusing great compression with a partially stuck motor. Could be a ring broke?
joetheis
What did the plugs look like when you got home? White? brown? black? wet?
If you got fuel GOING into the carbs, is it going into the engine, (clogged jet)?
If it has a NICE blue spark, and the key is good, so we're pretty sure it's sparking at the right time.
You ran a compression test-was it good? What is it? compression reading (WOT and spark plug grounded) and then again with a little oil in cylinder, ( seals rings, should be the same- then are rings good or if it's higher- ring worn, not sealing)
Try with the plugs out, blowing air into 1 cylinder and see if you can feel it coming outta the other (blown head gasket)
Try NEW plugs.
SOMETIMES a oil fouled s/plug will spark nice, but not under compression.
Joe
Remember to take any advice I give with a can of beer er 2!
jimp37
Does this have an external tank w/ primer bulb, or a built in tank?
