15hp Johnson running on one cylinder
Dj00140
Hey I have a 1979 15hp johnson outboard I just got this summer. I had the carbs cleaned and it ran great well my friend put to much oil in the gas (maybe 1.5x the correct amount) and it intermittently would lose power and go to one cylinder. Eventually the top cylinder stopped working completely. I have a white sludge coming out of the prop, when i pulled the plug it was not firing so i replaced it but the problem persists. The plug did look wet when i pulled it. I have not done a compression test and am just assuming the top cylinder isnt firing due to the wet plug and white sludge which i was told was unburnt fuel. What can I try next? Thanks in adcance. It still starts and runs great just goes half speed. Once i replaced the plug i was getting spark on both cylinders.
Chinewalker
White sludge would indicate water intrusion. Check that top plug for water beads or moisture. A compression test may be in order, too, as it might point towards a blown head gasket, which could cause both of your symptoms (running on one cylinder and milky oily residue).
Dj00140
I am in MN, and have been running it only in 30 degreee+ temps, but I could see some water getting stuck in there and freezing during the night time after I get off the water but I will go buy a compression tester and also check the gear oil and plug tonight for signs of moisture. I just started noticing the white sludge since I have been running it in cold weather but I could have missed it before... Thanks.
raczekp1
just take off head, go to maschine shop to flat the head surface.
i usualy do this and maschine shop takes of 0.35 mm head surface to get it flat.
Order new head gasket and install
if water gets to cylinder in high speed so will not compress as air do and con rod will not survive
but if you check spark when spark plags are out and no spark so it means coils is bad ( boot, cable or coil) or powerpack is fail.
the best to check it is to try other runing powerpack
oldboat1
think I would check the running temp, and do a compression check. If the motor is running running too cool in the first place, running in cold weather and water will be worse.
If working on temp issue -- The t.stat is a little hard to get at. Removal of head the best way, then remove t.stat cover. Test/replace thermostat. Need t.stat cover gasket and head gasket. For both covers, will want to resurface -- use wet/dry sandpaper on a piece of glass, iron table saw top or similar. If the compression test showed an issue, the new head gasket may help. And if there is water intrusion, the head gasket may resolve that. If temperature issues, check and clean out the water passages while the head is off. And---may be due for water pump work.
For all of that, you may be fine without any additional tinkering -- Use a spark tester to insure good spark; check temp and compression. Run 50:1 and keep your friend up in the bow, away from the motor.
Dj00140
Thanks guys, ended up bringing it in and it was the cd box, when I got to the shop we checked spark again and only one plug had spark. The part was $40 used and he charged me $30 to put it in. Thanks for the response, this was a guy on Craigslist so im sure a shop would charge more. The new parts I found were $70-100. The white sludge was the unburnt fuel from the motor running on one cylinder.
