15hp gamefisher coil wiring problem
jameswest
i just replaced a new coil on my outboard . after three weeks of trying to finda new coil I FORGOT! how the coils were wired. the manual I have only shows how to wire a single cyl. system. It has a plastic holdown screw on one side with a plastic washer,and a metal on the other. I had a tech. look it over and he was also baffled. PLEASE help. model 225.581501 standard leg.
M
mrcrabs
Guest
Re: 15hp gamefisher coil wiring problem
Welcome to Iboats,
help us and state your model number, a 15hp gamefisher could be made by a couple different companys and have different coil setups
jameswest
Welcome to Iboats,
thank you for your reply. the model number for the 15hp force gamefisher is 225.581501 standard leg. please help and reply soon. thanks again.
M
mrcrabs
Guest
Yep, thats a Chrysler force engine, you may get more help on the wiring at the Chrysler Force forum
