What is the purpose of the cylinder drain on an '89 15hp force motor?? Thanks.
S sparks4540 Seaman Thread starter Joined Feb 20, 2004 Messages 50 Mar 17, 2004 #1 What is the purpose of the cylinder drain on an '89 15hp force motor?? Thanks.
S sparks4540 Seaman Thread starter Joined Feb 20, 2004 Messages 50 Mar 18, 2004 #2 Re: 15hp force cylinder drain This is also called the recirculation valve and is part of the recirculting fuel system. It has two little screens and two check valves in it. Can anyone explain the purpose of this valve?? Thanks.
S sparks4540 Seaman Thread starter Joined Feb 20, 2004 Messages 50 Mar 21, 2004 #3 Re: 15hp force cylinder drain Can this thing cause the nearly 2000rpm fast idle???
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,988 Mar 21, 2004 #4 Re: 15hp force cylinder drain I'd love to help you if I could.
