Hello All,
I have a 1979 15hp evinrude on a 14' aluminum boat and the motor tops out around 5,200 rpms max with a light load (me and gear and battery ~ 250 lbs) which is around 16 mph at the very most. I posted a comment on an existing thread, but didn't get any response, so I thought I would start a new thread. The most concerning thing is the lack of rpms. It should be 1,000+ higher to get to the rated hp.
So far I've done or will do the following:
---compression is 110 on both cylinders
---replaced plugs
---readjusted throttle throw to open the throttle plate a bit past WOT to make sure I was all the way open
---replaced the existing 9.5x10 prop with a new 9.25x9 prop. (RPMs didn't go up at all, speed went down by 2 mph)
---de-carbed the motor with seafoam in the gas, sprayed in the carb and in the spark plug holes. Idled a bit better and started a bit better but no affect on top end rpms.
---Removed the carb and verified that it is clean (previous owner replaced float and the metal float bowl was virtually free of rust and grime). I ordered a carb kit and will install that when it comes in. The high speed orifice plug didn't appear to have any obstructions, but I cleaned it anyway.
---I'm considering custom drilling my own plug at 0.052" as I'm at 4,000 ft.
---Fuel pump leaked fuel when I took it off the crankcase. It appears this is the original because it is missing the rear gasket that was added to kits later. It doesn't appear the diaphrams are leaking into the crankcase. The pump was leaking out of the two small vent holes. The pump worked enough to operate the boat. Sometimes at WOT I would pump the bulb to see if there was low psi on the pump. This didn't increase the rpms at all.
Anything I'm missing? I know I should get more out of this motor. I had a similar 14' aluminum boat that would go 14 mph with a 5 hp newer motor and just me in the boat.
Thanks!
gabebp
---replaced plugs
Thanks!
gabebp
