Gulfsurfer
Thread starter- Joined
- May 9, 2006
- 33
1998 Cobia, new to me so I don't have any histrory except I've been thru the fuel system (all new fuel lines, racor filters, etc.) and cleaned up 9 yrs of Saturday boat maintenance and half !@#ed electrical repairs.
Dual Yamaha 150s, L150TXRW (port) & S150TXRW (stbd).
Stbd engine has the probs: oil won't xfer from remote to engine tank, even w/ the bypass switch. Tach for same engine not indicating rpms. LCD on, reading 0 rpms. checked green wire behind tach, it's connected. Seem to think this may be related to lack of oil xfer because of yr of engines (newer than 1995).
OK, I've searched and read the threads, read the Bass & Walleye article, done the prelim troubleshooting and am asking for help. Actually if I had a wiring diagram (rigging guide etc.) I could probably find the problem much easier.
Sourcing the pump at engine connector w/ 12V, pump runs.
Tested the harness between the engine and remote tank plug, harness rings out good.
Cleaned remote tank, tested switch at remote tank: pull switch out, simulate low level, and yellow indicator indicates, just like it should.
Haven't done anything w/ the engine oil tank switch beyondftaking it out and verifying the float is free. Feel like the bypass switch should do just that, bypass everything except the engine oil tank. Oh, I checked the bypass switch, it's changing state from NO to closed when toggled.
Does anyone have any info on tach wiring so I can elimate that from the equation? or any other suggestions.
thanks,
RM
thanks,
RM
