150hp Merc tilt trim problem
riverat82
I have a 150hp Merc. The tilt trim motor is square model with 3 wire hookup. When I supply power to it, it runs at high speed with no tilt action and without me pressing the tilt switch. But when I do press the tilt switch it stops, then quickly runs up to high speed again with no action... Thanks for the help..............
tramp666
Re: 150hp Merc tilt trim problem
get a manual for the wire diagram some oil and be glad that it spins the rest is downhill.
A three wire trim pump will have two solenoids. It sounds like one of them is stuck in the energized positionj, or your tilt switch is bad. Fix that first. After you get the switch to run the motor properly, you need to fil and bleed the cylinders and pump. Without knowing the kind of PTT system it is difficult to provide the bleeding procedure.
rdnk_4_lf
well i agree with that guy about the selinoid is stuck the reason its not going up could be a o-ring letting air in and its not getting the right pressure be sure to get some trim lube or whatever it is and dont run it much without it or you will tear something up thanks, nick :confused:
