150hp Force Question
TRAVIS95
Hi,i Have A 1990 150hp Force And The Problem Is The Motor Runs Fine Till It Gets To Normal Running Temp Around 20-30mins And It Starts Missing Bad And Motor Starts Dieing It's Giveing Me A Fit Runs Fine While Motor Is Cold What Few People I Have Talked To Say They Have Never Heard Of That Kind Of Problem.can Someone Please Help Me?
pnwboat
Re: 150hp Force Question
Many things can cause the symptoms you are describing. Need to try and narrow it down. May be a fuel delivery problem, or electrical ignition problem. I would suspect an ignition problem. Can you check the spark when the problem is occurring?
moparman
sounds like coil or box getting hot and shutting down. Do as Pnwboat suggested and check spark when it acts up and post the results
TRAVIS95
Thank You For The Help,i'll Get That Checked And Let Ya Know What Happens..
